02-10-2017 03:17 AM
32 12
tools
  1. Rumblee1's Avatar
    In order to take advantage of the powerful audio system in the A7, must you use the built in music player or can you download your favorite player?
    Guytronic likes this.
    11-03-2016 11:13 PM
  2. LeKeiser's Avatar
    Hello,
    Some apps let you use the Dolby application, some don't. I have tried a few, and Rocket Player does. So I bought it, it's a a good app. PowerAmp if my memory is right, lets you use it to.
    I think you have to try the trial ones and see which one you prefer
    huntnyc likes this.
    11-04-2016 02:14 AM
  3. Rumblee1's Avatar
    Hello,
    AWSUME, all i use on all 4 of my devices is rocket player ftom jrt studios. Thanks.
    11-04-2016 09:05 AM
  4. Rumblee1's Avatar
    Hello,
    How do you get to use atmos with rocket player
    11-14-2016 08:33 PM
  5. Soreloser's Avatar
    I couldn't get it to work with Rocket Player, only with the built in music app.
    Edit: just tried it with my Bluetooth headset and it works fine with Rocket Player. I just turned it on in settings>sound.
    11-14-2016 09:20 PM
  6. Rumblee1's Avatar
    Ok, got it. To bad jrt doesn't incorporate a single icon to turn on straight from the rocket player app.
    11-15-2016 03:53 PM
  7. Rumblee1's Avatar
    You are correct. I shouted out to JRT studios about this and they did reply that at this time, rocket player does not support dolby atmos. But the stock music player is, actually, pretty good. And eith dolby, wow.
    11-16-2016 07:00 AM
  8. Soreloser's Avatar
    On my Axon 7 when you swipe down from the top of the screen it brings up settings, and if you swipe down again it extends the list. One of the buttons is for the Dolby, to toggle it on or off.
    11-16-2016 09:10 AM
  9. Rumblee1's Avatar
    Well I uninstalled rocket player. When I listened to music on the stock player, dolby atmos worked no problem. When I tried it on rocket player, not only did it not work, but it froze dolby in the off position. In order to get it working again, I had to reboot my mini.
    11-16-2016 07:05 PM
  10. Soreloser's Avatar
    I have the paid version of Rocket Player and I use the 10 band equalizer that is built into it rather than the Dolby.
    11-16-2016 11:51 PM
  11. Rumblee1's Avatar
    Iv got RP premium too, but it shuts dolby down till I reboot. Strange.
    11-17-2016 08:21 AM
  12. Soreloser's Avatar
    It does have some weirdness to it. That's why I just use the built in eq.
    11-17-2016 11:08 AM
  13. russ8128's Avatar
    The built in player is actually ok. Sometimes Spotify, Amazon Music and Pandora can access the Dolby app, sometimes I have to start playing some music in the built in player, start dolby and then use Spotify, etc. A little workaround...
    11-20-2016 05:46 PM
  14. javyn's Avatar
    Phonograph works fine with the Dolby app.
    I've heard Neutron is a great music player because 64bit processing or something, but honestly the UI is so ugly I couldn't get past that aspect to even bother testing the sound quality.
    I'm very picky with UIs for music and podcast players since most of the time I'm using those apps while driving.
    11-21-2016 05:22 PM
  15. Rumblee1's Avatar
    Well, I decided to just stay with the stock music player. Since the reason I bought this was for the sound reproduction, the looks of the UI doesn't bother me. Its that dolby sound I want. By the way, I was so impressed with this phone, that when I saw the black Friday deal from Newegg, I grabbed the A7. 349.00 + beats headphones and black & decker coffee maker. I would have bought the A7 premium if it had the 821 chip, but couldn't see spending another hundred bucks for 2 more gigs of ram that we'll never use. Plus I really dont care for the gold color. With ZTE offering such large discounts on their phones, I've got a feeling that an A8 is right around the corner.
    11-26-2016 07:36 AM
  16. Rumblee1's Avatar
    I received an astell&kern high resolution music player for Christmas. After downloading a few hd albums, i thought I'd put them on my A7 to try them out. I also downloaded the onkyo high rez music pkayer. I couldnt believe it, but the A7 sounded better either with or without the Dolby enhancement. It was superior to the A&K. This phone is wonderful. Works like a charm on everything except won't wake when I say "hello Google" if screen is off. It'll only reply when screen is on. And yes, ive got it set to answer in all screens.
    01-15-2017 02:33 PM
  17. OhAlfie's Avatar
    Looking at my "ok google" setup, I have ZTE "My Voice" stuff "off". I have Ok Google for all screens on, trusted voice, on and I can activate Ok Google when screen is locked.
    01-16-2017 09:50 AM
  18. Rumblee1's Avatar
    Ive been through every setting in my google app and phone settings. I've got my voice all off, and ok goigle for all screens on. I cannot find a setting for "trusted voice" anywhere on my device either under device settings or under Google settings.
    01-16-2017 10:59 AM
  19. OhAlfie's Avatar
    Go to Google app...settings...Voice..."Ok Google" detection..."trusted Voice". turn on.
    01-16-2017 11:23 AM
  20. Rumblee1's Avatar
    Sorry, did exactly what your instructions said on both my A7 & pixel. No trusted voice option.
    01-16-2017 09:21 PM
  21. canawler's Avatar
    Unless ZTE does things differently, access to Trusted Voice is through device settings > security > smart lock.
    01-16-2017 10:00 PM
  22. OhAlfie's Avatar
    I just accessed "Trusted Voice" via the Google app with the instructions I wrote out above. I just went back into Google setting just now and the option is there to turn on/off.
    01-17-2017 09:27 AM
  23. OhAlfie's Avatar
    Screen cap found online:
    01-17-2017 10:21 AM
  24. Rumblee1's Avatar
    Well, I figured out why it's not on my setting screen like yours. I'm not using a secure lock screen. .
    01-17-2017 06:21 PM
  25. Rumblee1's Avatar
    I love the axon7. It's just as good as my S7 EDGE and a hell of a lot better that my pixel that I sold. Anyway, I downloaded 4 movies. When I watch these movies and use wired headphones, all is fine. When I watch and use bluetooth headphones, the soundtrack is way off. Anyone else have this issue?
    02-07-2017 04:01 PM
32 12
  1. Audio Quality
    By LezCronut in forum Google Home
    Last Post: 11-26-2016, 07:31 AM
  2. Question about security updates
    By JenTDOT in forum Moto Z
    Last Post: 11-20-2016, 01:25 PM
  3. [APP] New app that lets you cast youtube to chromecast audio
    By Sibi Mobile in forum Google Chromecast
    Last Post: 11-03-2016, 10:06 PM
  4. Moved to T-Mobile from Sprint, Questions about swapping sims in and out.
    By QuantamPulse in forum General Carrier Discussion
    Last Post: 11-03-2016, 08:22 PM
  5. Question about posting photos on here from Google photos
    By amyf27 in forum Samsung Galaxy S7 edge
    Last Post: 11-03-2016, 11:42 AM
