1. technerd4life's Avatar
    Anyone have any luck activating visual voicemail for T-Mobile on the Axon 7? I had customer service activate visual voicemail on my line, but I have not been able to get the app to recognize the activation. Standard voicemail does record messages, and I can access them using the dialer, but I don't get any notifications if a message has been left. I much prefer using visual voicemail for reliable notifications and a variety of other added functionality. If you've been able to get it to work, were there any particular steps or settings that you had to apply? T-Mo tech support hasn't been much help.
    08-10-2017 05:23 PM
  2. Sedp23's Avatar
    All i had to do was install the app and it worked didn't have to do anything special and I got notifications for it
    08-10-2017 08:28 PM
  3. technerd4life's Avatar
    Good to hear. I'm suspicious it has something to do with my account. I may need to go into a corporate store.
    08-11-2017 06:30 AM
  4. foxbat121's Avatar
    Voice mail notification, without visual voicemail part, is a basic Teleco function that works quite reliably. Visual voicemail app won't improve that. In fact, it probably depends on it. It seems your account has problem.
    My Axon7 has a problem with call forwarding settings from phone. It won't work. I have to call AT&T to fix it. It turns out the IMEI number wasn't auto updated in their system and still points to my old phone. This never happened to me before. I swap phone quite often.
    08-11-2017 09:18 AM
  5. Phyllis Haberkamp's Avatar
    I had the same problem with my Alcatel. I had to turn off the visual voicemail option in my phone dialer. Go to setting and voicemail and turn it off. Then the vvm app activated with no problem.
    04-13-2019 09:00 PM
  1. i have the solution to the lgg3 wifi problem
    By AC Question in forum LG G3
    Last Post: 12-31-2017, 05:34 AM
  2. lg optimus 3d won't turn on after baseband v20c flash and reboot
    By Tudor Andrei Raneti in forum LG Optimus 3D
    Last Post: 08-18-2017, 02:37 PM
  3. How do I turn on "ok Google" on Android 7.0?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 08-16-2017, 04:23 AM
  4. How do I turn on "ok Google" on Android 7.0?
    Last Post: 08-10-2017, 04:52 PM
  5. i have the solution to the lgg3 wifi problem
    Last Post: 08-10-2017, 04:03 PM
