1. Rumblee1's Avatar
    My A7 won't go more than 5-6 hours with little use.
    08-31-2019 02:41 PM
  2. Rukbat's Avatar
    Do you normally let the battery run down below 40%? If you do, you're killing it. Either live with it or pay to have it replaced. (Even if you don't, batteries are "consumables", they're not covered under warranty, unless the phone is only a week or two old.)
    09-01-2019 02:16 PM
  1. S10 intl roaming problems -- bad LTE connection + battery drain/overheating
    By Josh B DC in forum Samsung Galaxy S10 & S10+
    Last Post: 09-01-2019, 02:24 PM
  2. Android 9 (pie) uses a lot of battery
    By Android Central Question in forum Android Pie
    Last Post: 08-31-2019, 11:03 AM
  3. Android 9 (pie) uses a lot of battery
  4. Does "Wi-Fi preferred" save battery?
    By MrDoh in forum Samsung Galaxy S10 & S10+
    Last Post: 08-30-2019, 07:35 PM
  5. App to replace Aviary? [Filters].
    Last Post: 08-30-2019, 04:52 PM
