ZTE Axon 7 (ZTEA2017U) won't turn on
WheelmanM80
17
The device will not boot up. Every 15 seconds, the device vibrates once and the notification light flashes once. Only holding all three buttons stops the vibrate/flash cycle. Holding any other combination of buttons does nothing. Nothing shows up on the screen during the vibrate/flash cycle. My computer also does not recognize the device when I plug it in, whether in its vibrate/flash cycle or after I hold all three buttons. I'm not sure if it's charging, because after pressing all three buttons to stop the vibrate/flash cycle, the notification light doesn't stay illuminated red or green while plugged in. Is there anything that I could check internally if I took the phone apart? Maybe a connection worked itself loose? I would very much appreciate anyone's troubleshooting ideas on this, and thanks for your time.
I understand that many things could cause this, but I'd really appreciate some troubleshooting ideas here. I'll be taking the phone apart this weekend to inspect all the connections. I have experience building desktop computers and laptops, but other than that, I won't be able to spot, for example, a gpu or processor that isn't set correctly. Any tips for what else to look for would be extremely helpful.
The first thing to come to mind would be a failed battery. You could try checking the voltage of the battery, or just replacing the battery.
Wow, good work! Glad you didn't have to do anything more drastic.:)
r3dpuk3
