1. Everythingnook's Avatar
    Heres a video i made about the Nook Color running ICS
    [YT]http://www.youtube.com/watch?v=pK31qFP9iwA[/YT]
    burkett1974 and auburngirl like this.
    12-10-2011 06:51 PM
  2. auburngirl's Avatar
    I have been wondering how the NC would run ICS. Do you find it to be laqgy at all?
    12-12-2011 08:11 AM
  3. digitalslacker's Avatar
    yeah it's still laggy
    there's a thread over at XDA where you can follow the dev work
    [DEV] CM9/ICS Work-In-Progress - xda-developers
    there's a download to an early buggy alpha...
    auburngirl likes this.
    12-12-2011 11:05 AM
  4. koopakid08's Avatar
    I tried it out. I found that it was as quick if not quicker than CM7 after overclock plus V6 script. It felt great to use a tablet OS but no sound is a deal breaker for me.
    Sent from my LG Optimus V using Tapatalk
    auburngirl and rodman246 like this.
    12-12-2011 07:56 PM
  5. Everythingnook's Avatar
    It laggy doing somethings (i find the stock browser laggy) But i still say its usable as a daily rom.
    You can try it out with the link digitalslacker posted.
    12-13-2011 01:25 AM
  6. vcsekhar's Avatar
    I couldn't find a reliable Gapps for this version. The one at http://www.android-advice.com/file-d...gle_Apps_Flash isn't working fine on my NC in that inspite of the CWMRecovery reporting the installation as successful,
    1) It only displays the Google Market icon and nothing else in the apps-screen
    2) The installed Google Market aps struggles to connect to the internet - takes lot of time
    3) The Google Market app fails to authenticate the supplied gmail credentials,
    4) After a while it simply fails displaying a message couldn't connect with a retry button and any number of retries doesn't work out.
    Will share more once I get to install a working GApps set.
    Update on Gapps - http://wiki.cyanogenmod.com/index.ph...on#Google_Apps worked for me
    Thanks
    VC
    07-18-2012 10:35 AM
  7. elwood0523's Avatar
    It's buggy and lags. Sometimes apps just close on thier own repeatedly, Some apps open as just black screen. Havent had any problem getting on the internet or to googleapps, but a tad slower than cm7. Cm7 runs truly magnificent on my nook and i would never use the ics alone that I currently have.
    07-24-2012 04:18 PM
