1. The-Red-Hood's Avatar
    i was trying to put cm7 on my nook and i couldnt get it to work, so i am just trying to restore. i downloaded nook 1.4.1 and i did the install from zip in clockwork. i started up the nook, and when i try to type in my eamil for b&n the keyboard just keeps flashing away (down) and i cant type. what can i do to get my nook back to factory settings and be able to type ?
    06-26-2012 02:58 PM
  2. CRS1's Avatar
    When you get your Nook to work again, install CM7 and run it off the MicroSD card. It runs great!
    I have CM7.2 running off the MicroSd card.
    Sent from my ASUS Transformer Pad TF300T using Tapatalk
    06-26-2012 04:43 PM
  3. The-Red-Hood's Avatar
    ok, just an update, i was able to get it working after doing the failed 8 boots. its all up todate. but to explane what was happening with the cm7. i followed a few different tuts. on youtube (i mean they are all pretty much the same) but i was loading cm7 on to the internal nook memory. it loaded up but when it came to installing google apps they never installed and the market kept crashing. and one other time i was geting something along the lines of "something something has crash/ended unexpectedly. closeing now" something like that. so if anyone has any imput. i followed the guide on here as well.
    06-27-2012 07:24 AM
