I've ran into a problem. I overclocked it, selected "clear cache & data" after selecting the file through ROM manager. I've lost everything. My screen is the initial screen when rooting NC and my screen doesn't recognize my touch. I need help. Can I get back to where I was?
Update: It's wiped everything clean...under Settings I'm not registered as the owner now.
After selecting " Install from SD Card" there are 2 options. backup or wipe clean (i think), which one is the correct one to select?
Yeah, you wiped your data. I think you clicked on the wrong menu. Install from SD should only let you choose a zip - not wipe your data or backup.
If everything works fine, you may not need to restore to stock in order to continue re-downloading all your apps, but if you get any errors, that will be what to do (see stickied restore to stock thread).
At this point, the only way to get your data back (aside from manually re-installing everything you had) is if you backed up via Clockwork or something like Titanium Backup.
