1. zakth's Avatar
    Yesterday I purchased a Nook Color from Best Buy with the intentions of using it as an Android Tablet. With tax my total came to $264.99, not too bad for an Android Tablet. After getting home I started the Nook Color for the first time and followed the on-screen setup wizard. Within only a couple of minutes I was ready to explore the Nook Color.
    One of the first things that I noticed about the Nook Color was that the screen, while it appears to be glass, was not smooth to the touch like Cornings Gorilla Glass. The second thing I noticed was that on some screens you can see the light in the background of the device flickering like a CRT using a refresh rate that it cannot handle. This problem only appeared when viewing primarily white backgrounds. The device felt sturdy in my hands and the rubberized backing on the device was a nice touch. The Micro SD slot on the device is located in the lower left corner where the Nooks hook is. In my opinion this is not the best placement for a Micro SD slot as I had some trouble inserting and removing the card.
    The software is heavily modified and provides a limited experience. Its definitely not what I would consider an Android Tablet out of the box. The book reading portion of this works great, it even reads some books to you. Pandora is provided on the Nook Color and it works just as well as it does on any Android device. There are also a few games that come with the device such as Sudoku and Word Search but I honestly did not try any of the games.
    There was no Market application on the device and I did not see anything on the Nooks website that would allow you to download additional applications such as Facebook for Android or even Angry Birds. This was a bit of a disappointment to me because had they included a Market application by default then I think the Nook Colors potential could be much higher.
    So we all know that the Nook Color can be rooted, it can run Froyo from both an SD Card and internal memory. It can even run Honeycomb from an SD Card and internal memory. I decided to root my Nook first. But for some reason I was never able to authenticate with Google so the Market never worked for me. Thats when I decided to try Froyo on SD. It seemed to work fine despite being sluggish. I was however unhappy with how small the icons where considering this is a tablet. The screen also seemed to have some problems registering touch in the correct places. Since I was unhappy with Froyo on SD I decided to install Honeycomb on the internal memory. I followed the steps and within minutes I had Honeycomb up and running. I really liked the interface but market would not download any applications. I tried doing the fix that was suggested but after that market loaded to a white screen with an error box in the background that you could not see but for a split second after exiting the market.
    After exploring the above mentioned mods I decided to return the device to stock. First I ended up using the pre-rooted stock and it worked flawless with the exception of not authenticating with Google. I then used the 8 boot method to re-flash the device and followed that up with the data wipe. Now my Nook Color is back to factory condition. I gathered everything that came with my Nook Color and put it back in the packaging along with my receipt. Later today I will return to Best buy and get a refund for this device.
    If you are in the market for an Android Tablet I would suggest you stay away from the Nook Color. While it is cheaper than other devices it is currently lacking a stable and efficient operating system from the development community. Dont get me wrong, I think the work that has been done so far is great but comparing the hacked OS this device has to the Galaxy Tab on the same OS well its like night and day. If you are however in the market for an eReader and would like the added bonus of it having Android, however limited it may be, then this device most certainly be for you.
    02-13-2011 12:45 PM
  2. pceasar's Avatar
    Sux it didn't work out for you, I must say its unfortunate that 1 or 2 on the fringes are not able to get things like Market to work. Nonetheless I agree that its not turn key but I have had no such adverse issues with my under 260 tablet.
    Actually about to go get a case for it now.
    02-13-2011 01:03 PM
  3. creighton's Avatar
    Same here. For $250 I'm surprised it works as well as it does.
    02-13-2011 01:07 PM
  4. Smokexz's Avatar
    Look, no one ever marketed it as a tablet. Barnes and Nobles says they will release froyo with support for the Android Market, that's at least close enough to a budget tablet. If you wanted a tablet you should have gotten tthe Deal Streak 7,probably the most affordable Android tablet ever.
    Sent from my Nexus S
    02-13-2011 01:09 PM
  5. imtravis's Avatar
    I bought mine knowing it was an eReader.. I just liked the bonus of being able to turn it into a tablet.. and I've not been unhappy with that purchase. I think buying it because it's a "budget tablet" is the wrong reason, unless you've read, and understand that it takes some work.
    02-13-2011 01:45 PM
  6. zakth's Avatar
    According to B&N, while the Froyo release may have the Android Market it will not have access to all the apps in the Android Market. At this point I do not think anyone can say for sure what we will be able to download.
    02-13-2011 02:28 PM
  7. BugsBunny891's Avatar
    Nice troll story. Nook color = ereader so i don't see the point of this topic in the first place
    02-13-2011 03:19 PM
  8. zakth's Avatar
    This was not intended to be a troll story. I was simply giving my own personal opinion on the product as I experienced it.
    02-13-2011 03:30 PM
  9. sushi's Avatar
    While I appreciate your honest story, I have to say that my experience has been vastly different. Perhaps because I paid much, much less than retail for the NC, and it's not my primary device (my wife is using it daily), but it's a snappy little tablet, even when you just root the default config. There are some minor bugs, but there are even issues with my Sprint Epic and my iPad.
    02-13-2011 03:40 PM
  10. sweaner's Avatar
    I used a pre-rooted micro SD purchased from eBay. After setting it up, it seems to work flawlessly. I think I have a pretty good $300 tablet.
    02-13-2011 04:01 PM
  11. gog8rs#WN's Avatar
    I bought one for the wife yesterday. I am *delighted* at its core tablet functions.
    Perfect web browser / email for home use IMO
    Sent from my PC36100 using Tapatalk
    02-13-2011 06:09 PM
