Problem - How to Unroot Honeycomb in Nook Color
muilaiman
I've used honeycomb for a few days and wanna go back to the usual rooted nook color, via autorooter since it works faster than honeycomb. Does anyone know how to unroot honeycomb or install froyo on the internal memory to delete honeycomb?
Thanks in advance!
lebrunj1
same problem here have, you come up with anything? I have tried and tried but for some reason when I install my sd card the NC boots from the internal memory and not the sd card. I like honeycomb and all but I like Froyo better, now I wish that I could get back to it. My main problem right now is that I installed HC on the NC internal memory and when I try to unroot it from an sd card it boots up from the internal memory and not the card.
Laila Nance
