I see on my stock rooted NC that the biggest battery user is related to celluar applications which I obviously don't need. Reading the Nookie Froyo work around thread, I see some instructions for how to remove/rename and invalidate the files that are the issue here.
Will the same work around work on the rooted stock configuration? Can I get the Root Explorer app and fix this by renaming the files that way?
Thanks,
Brian
Thanks,
Brian
