When I launch Titanium Backup I get this message:
Your system settings prevent you from restoring applications. To correct this, go to your phone's Settings. Then in "Applications", tick the "Unknown Sources" checkbox.
1. I haven't been able to find this setting.
2. They're right - when I try to restore an app, I get this message:
"Installation of download apks is not supported"
Does anybody know how to fix this?
My device is a rooted stock NC.
