So I rooted my device using autonooter 3.0. I then have a bootable microSD with honeycomb on it. Loving honeycomb but have an issue with the market.
The only instructions I have seen on how to get android market on it is using Android SDK/ADB. I have been following these instructions NookColor USB ADB - nookDevs
with not much luck for the past few hours.
I have the market on the internal memory due to rooting. Is there an easier way to get the market than following all those steps on the link above? If I flash honeycomb directly onto the internal will that make the process easier? Should I go with Gingerbread (would rather keep honeycomb but it's an option)?
Any help/advice would be appreciated.
Thanks.
Thanks.
