So, I did the manual update this morning and am loving the additional capabilities. The first app to be downloaded was Angry Birds (of course). Unfortunatley, I experienced a problem in that it would not install. Found this on the Barnes and Noble site:
Worked like a charm. Will be playing at lunch.Q4: When I try to install “Angry Birds”, I get an error. Help?
This issue is being investigated by our engineering team.
WORKAROUND: Please remove any microSD cards from your NOOK Color and try again. You can reinsert the card after installation has completed.
