My nook is really messed up!! I'm so upset. I think I erased everything by accident. It will NOT boot up. I only get the android with the blinking cursor. It wont recognize my SD cards. I did have CM7 running internally on it and loved it. All I wanted was to update to nook 1.2 then run CM7 on SD card. Now it is totally gone!!! Help!
PS...I'm on a MAC and all the instructions are for a PC...
