1. Bravo#AC's Avatar
    Anyone had issues with the power button on their nook not working? Only way I can get my nook to wake is by plugging it into the power cable. I rooted using autonooter and was going to try and just restore and re-root but I can't figure out how to restore without having a working power button. This issue happened about a month after succesfully rooting device.
    06-07-2011 10:56 AM
  2. pzish's Avatar
    I had the same problem but I find that if I press the power button and the N button at same time the nook boots up. Hope this helps.
    06-08-2011 11:38 AM
