Please try it and give your feedbacks. Thanks!!
https://forums.androidcentral.com/e.../details?id=com.linpus.battery&token=5GHmA05a
Linpus Battery Optimizer is a fully featured battery management and optimization tool with several stand out features compared to other free battery apps:
Time left per app
Linpus Battery Optimizer intelligently monitors battery usage for each app over time to calculate and instantly update the length of time you can use an app for before the battery is drained. For example, want to watch a movie, it will look at how much battery you have left and estimate how many hours before the battery dies. You can therefore plan if you can watch all the movie or not, or you need to close other apps or charge.
Application management UI
Linpus Battery Optimizer lets you not only see which app is using the most power, but let you kill it immediately without having to go to another panel like so many battery apps.
Charging Stages
Has Trickle, Fast and Full Charge stages. Many batteries appear to be full, the Trickle option means you squeeze an extra little juice into your battery before you unplug.
Power usage plans
Has Balanced, Power Save, Super Save and User Custom modes
Intelligent power saving
Can automatically disable wireless connectivity when your battery gets below a certain percentage
A full list of features is below:
Battery Info:
- Show battery health and temperature.
- Show time estimation and percentage for battery usage.
- Show time estimation and percentage for charging.
- Show battery life for different scenarios, e.g. standby, call, video & music playback, web surfing and so on.
- Supports learning mechanism to adjust time estimation dynamically.
Charging:
- Supports fast charge, full charge and trickle charge.
- Show tips for different charging stages.
Consumption:
- Show instant power consumption for each app with ranking.
- Can kill an app from the app list.
- Show instant power consumption for hardware components with rankings.
- Can adjust the setting for each hardware component.
Power Plan:
- Supports three pre-defined modes: Balanced, Power Save, and Super Save modes.
- Records initial settings to User Custom mode.
- Users can set values as they like for all modes.
- Show time estimation for each mode.
Intelligent Power Saving:
- Can automatically switch to another mode when the power is lower than a certain threshold.
- Can automatically disable all connectivity when the battery goes below a certain threshold.
Others:
- Provides useful power saving and battery maintenance tips.
- Show notification when the battery is fully charged.
- Show notification when the battery is lower than a certain threshold.
Time left per app
Charging Stages
Power usage plans
Battery Info:
Charging:
Consumption:
Power Plan:
Others:
