Need Help in the Kitchen! (UOT That Is)
DefectiveWeeble
158
8
Ok. So I have my Bionic rooted and romed, however, I wanted to do a different battery icon and change the font. I went to UOT Kitchen and fixed everything up. I have the framework-res.apk and systemui.apk uploaded for it an everything, but when I try to flash it in recovery, it just says "installation aborted" No error, nothing. Just "installation aborted". I tried turning signature verification on and off, tried the workaround that UOT suggested, which was taking the update-binary file from the ROM and putting it into the zipped UOT folder, and that did nothing. So, any other ideas?
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Could be script error with the package that you selected from the kitchen.. Grab a working flashable zip like a theme that you know "works" and remove everything from it leaving the framework and app folders in place. Then open the UOT zip and take the framework-res.apk and drop it in framework and the SystemUI.apk and drop it in app and use that zip to flash it....
Then at least you you know your working with a good script/zip package.
Little process of elimination, help narrow things down.
Reactions: DefectiveWeeble
DefectiveWeeble
158
8
Is you flashing in stock recovery or clock recovery?
Sent from my DROID BIONIC using Tapatalk
I'm attempting to flash it in CWM recovery. Do you think that would make a difference?
Could be script error with the package that you selected from the kitchen.. Grab a working flashable zip like a theme that you know "works" and remove everything from it leaving the framework and app folders in place. Then open the UOT zip and take the framework-res.apk and drop it in framework and the SystemUI.apk and drop it in app and use that zip to flash it.....
I'll see what I can do! Good plan, here. Thanks :)
DefectiveWeeble
158
8
Well, that didn't do the trick either :( Same thing. Installation aborted. No excuse as to why. I wonder if I can tell someone else what I want and have them make it work for me? Lol. Oh well. Any other ideas?
