1. DiamondDave's Avatar
    [Rom][Alpha] ICS4Bionic 01-25-2012 - RootzWiki - Page 251. Soon to be a new thread over at rootzwiki. I have installed and verified that this works.
    02-09-2012 07:23 AM
  2. mbentley3's Avatar
    Nice! waiting for .902 to hit "officially" hopefully by then the ROMs 4G connectivity will be stabilized.
    02-09-2012 04:38 PM
  3. Cvballa3g0's Avatar
    Also installed. Data works on the ROM. It is now my Daily Driver!!!
    02-09-2012 08:39 PM
  4. mlj01's Avatar
    I also have this installed, stable 3g connection, i have heard of problems with sending or recieving texts, but I would guess that would be common if your connection isn't stable
    02-09-2012 11:45 PM
  5. Striker840's Avatar
    My biggest issue I have been having is network connection error...get it even when I am at the house it seems to drop the wifi, installing the 902 update now.
    02-10-2012 08:53 PM
  6. Lefty Drummer's Avatar
    Just have to say that this is pretty awesome. I do miss the camera so I have stock .902 safe strapped and toggle. Really great work, once the camera's working and the need to manually toggle to get data is straightened out, this will be my 24/7 ROM. As someone who never loaded a rom before this past weekend (tried eclipse, a little sluggish to me), I'm happy I finally took the plunge. If you haven't already I recommend you try this. The wifi speed in particular seems much faster than on .902.
    02-15-2012 10:51 AM
  7. Mike Arvin1's Avatar
    Yes pretty well hidden, all but the crash error about google gapps, then go to that site, and low and behold, it's the aliases of people using operating system, click on person store to contacts maps shows location, now please get this off my s:':: A, S, A, P THX!
    01-13-2014 03:36 PM
