1. drstrangelove5's Avatar
    Yesterday I was at the beach and i turned on the auto brightness setting on my Bionic. The next morning the display brightness is so dim it makes using the device nearly impossible. I set an alarm on the phone. When i woke up the screen was fine. I put it in my pocket and when I pulled it out the screen level was so dim I thought the phone was off. the backlight works. I can clumsily fumble around and navigate the phone for tech support.Please help.
    I'm running 10.1.2 Stable CM
    09-02-2013 05:46 PM
  2. B. Diddy's Avatar
    Make sure the light sensor isn't blocked by dirt, a screen protector, or a case--if it's blocked, the phone will think you're in the dark, and therefore dim the screen to the lowest setting.. The light sensor should be near the front-facing camera. Make sure that whole area is nice and clean.
    09-02-2013 10:06 PM
  3. drstrangelove5's Avatar
    its clean
    09-03-2013 10:10 AM
  1. Nexus 4 - Need help, no os on N4, only TWRP
    By HaraldSchafer in forum Google Nexus 4
    Last Post: 05-14-2015, 04:15 PM
  2. Help!!! My Galaxy S4 is stuck.
    By booogas8 in forum Samsung Galaxy S4
    Last Post: 09-03-2013, 08:35 AM
  3. Dashclock Battery Extension Help
    By jrwestenberg in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-02-2013, 07:30 PM
  4. Need some help
    By Faithful9 in forum HTC One M7
    Last Post: 09-02-2013, 05:11 PM
  5. help with installing ROM on Sony Xperia Miro
    By snadge in forum General Help and How To
    Last Post: 09-02-2013, 04:59 PM
