1. Snake1949's Avatar
    I am running Android 10, Build # QP1A.190711.020, Custom build version
    BLU_G0370WW_V10.0.04.08_GENERIC 16-05-2022 14:11 on a Blu G90 Pro.
    I'm using T-Mobile (Tello) as a provider.
    I've had the phone for about 11 months and have never had any trouble
    sending texts until about 6-8 weeks ago. It seems the trouble started
    around the same time the latest update (security update I believe) was
    applied.
    The vast majority of my texts are sent while I'm at home where I use wi-fi
    (mobile works sporadically where I live). Texts I send very rarely get
    sent right away with the first attempt. I usually get the message
    "waiting for a connection" or "Sending ...", and then after some time I
    get the message "text not sent". Most of the time I have to try to send
    the text multiple times before it actually gets sent.
    Again, I had no problems sending texts before 6-8 weeks ago.
    Is anyone else encountering this? What could my issue be?
    I don't see how to reply or follow-up to this post so I'll edit my original post ...
    Thanks for responding, everyone.
    I'm not very proficient with smart phones.
    Laura ... I'm using the messaging app which came installed on the phone.
    I didn't even know there was more than one messaging app but apparently
    there is. In the app info the name of the app is just "Messages". And it
    is listed as an SMS app. I do use it over wi-fi. I rarely use mobile
    since my plan has limited data.
    mustang7757 ... I searched for Google Messaging App and when I touched on
    it I had two choices: to open it or uninstall it. So, apparently, Google
    Messages is what is installed on my phone.
    Mr Bojangles1 ... when I looked at the app info for the Messages app on
    my phone it alerted me to an update being available. That surprised me.
    I was under the impression that updates for any apps installed on my phone
    would be done automatically, or at least I would get a notification that
    an update was available. Anyway, I installed the update and tried one
    conversation since then. All my texts were sent smoothly. More testing
    is needed, but so far so good.
    07-18-2022 01:28 PM
  2. Laura Knotek's Avatar
    Which messaging app are you using? Keep in mind that if you're using SMS, you'll need a good cellular connection, since SMS will not work using WiFi.
    07-18-2022 02:29 PM
  3. Mr Bojangles1's Avatar
    Check for updates. Take your sim card out and reinsert. Maybe it's not sitting properly. Try soft reset, I think it's power button and volume down on your phone. If not it's volume up and power. It's the one that doesn't take you to recovery. You can also try resetting your network settings. This will remove saved passwords for wifi so you will have to re enter when connecting. Can also try clearing cache and possibly data of messaging app. Did it on my phone and text messages were still saved, but it's Google messages not sure if that's why. Also make sure that messaging app is set to default. Check your apn settings, maybe reset it.
    Laura Knotek likes this.
    07-18-2022 04:02 PM
  4. mustang7757's Avatar
    If you can OP download Google messages to get full rich chat features and work over WiFi
    Laura Knotek and J Dubbs like this.
    07-18-2022 07:30 PM
  5. Snake1949's Avatar
    Update - After trying more texts the issue persisted. I reset my networks and that seems to have helped.
    B. Diddy likes this.
    07-21-2022 02:29 PM
  6. mustang7757's Avatar
    Awesome glad it's good now!
    07-21-2022 11:45 PM
  1. Sms app that sends texts daily
    By donebrasko in forum Samsung Galaxy Z Fold 3
    Last Post: 07-24-2022, 01:38 PM
  2. Can't send video
    Last Post: 07-16-2022, 08:08 AM
  3. The 'Define' option in the Android text menu doesn't appear any more on my Pixal 6 pro phone.
    By Android Central Question in forum Google Pixel 6 & Pixel 6 Pro
    Last Post: 07-15-2022, 06:22 AM
  4. Replies: 0
    Last Post: 07-15-2022, 04:22 AM
  5. Replies: 0
    Last Post: 07-14-2022, 06:44 PM
