1. AC Question's Avatar
    Greetings,
    I tried to open an application and it wasn't loading properly. In hindsight I should have forced-quit the application. Instead, I decided to reboot my phone. Upon reboot I found I could not get past the BLU boot screen.
    From there, I found my way into the Android System Recovery options and chose the Wipe Data/Factory Reset option. I also wiped the cache partition.
    Now my phone boots directly to the Android System Recovery options every time I turn on the phone. I'm caught in a loop.
    I tried to install the Android SDK and attempted to run the following commands:
    adb shell
    #wipe data
    However I get the following error each time: Error: Closed. I updated to a more recent version of the Android SDK and I still get the same error.
    I'm using a BLU Advance 4.0L model phone that has NOT been unlocked. I use Ubuntu Mate on my PC. I've spent hours googling for solutions. How do I proceed from here?
    03-02-2016 12:06 PM
  2. B. Diddy's Avatar
    Moved to the Blu forum.
    03-02-2016 12:30 PM
  3. hisense's Avatar
    What was the application that started the problem in the first place?
    03-09-2016 01:37 PM
  1. What can be done to have the charging port fixed in my Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-03-2016, 01:12 PM
  2. Replies: 1
    Last Post: 03-02-2016, 12:43 PM
  3. Replies: 1
    Last Post: 03-02-2016, 12:38 PM
  4. How to check what's on my SIM Card?
    By MinchanH in forum General Help and How To
    Last Post: 03-02-2016, 11:15 AM
  5. What does sd card is blank or has unsupported files mean?
    Last Post: 03-02-2016, 09:20 AM
