Help Help Help Plz One Click Root Needed
You need odin
It currentl the only reliable method
Sent from my SPH-M820-BST using Android Central Forums
Yep don't use that one click root. Odin is the way to go. Found that out the hard way which is why I'm on my old phone. Don't think I'll be rooting the prevail anytime soon :thumbup:
Sent from my LG-LS670 using Xparent Purple Tapatalk 2
wobblefix
