1. aa6vh's Avatar
    Just a cautionary about the WSD-F10 charging cable. Be sure to unplug the cable when not using it to charge the watch.
    The charging cable connectors are too exposed on the watch side, and with the magnetic head, it is easy to accidently attach to a metal object, which will short out the cable if connected to power.
    Doesn't seem to cause a fire or anything, but the cable is now useless to charge the watch. Don't ask how I know.
    Fortunately Casio replaced mine under warrantee.
    B. Diddy likes this.
    06-15-2016 10:17 AM
  2. B. Diddy's Avatar
    Thanks for the heads up! That sounds like a significant design flaw. I've had magnetic chargers clamp on briefly to other metallic objects without a problem, so I wonder if it's something specific to that cable.
    06-15-2016 12:48 PM
  1. Wireless Fast Charging does not work when battery is 15% or below
    By merelogic in forum Samsung Galaxy Note 5
    Last Post: 06-16-2016, 11:57 AM
  2. Temperature too low to charge S6 edge
    Last Post: 06-15-2016, 05:53 AM
