1. voigts's Avatar
    I'm looking online at the 2600mah battery, but cannot find the thickness dimension. The 3500mah batteries for the i400 galaxy S on Ebay are 10mm thick, and I know the normal and 2600mah batteries for the two are the same. So I am wondering if the 2600mah is the same thickness or not as it wouldn't make sense to buy the 3500mah batteries if they won't fit the extended cover for the Charge.
    07-18-2011 05:02 PM
  2. bangpanther's Avatar
    The 2600mAh battery is about 12mm thick, otherwise the same dimensions as the stock battery.
    07-19-2011 01:15 AM
  3. dhp106's Avatar
    And there is someone who posted pics. Search for it.
    Sent from my SCH-I510 using Tapatalk
    07-19-2011 01:56 AM
  4. dhp106's Avatar
    Also I don't know about more than 2600 battery. There is a slim 1800 battery but users have trouble so far from Amazon ones.
    07-19-2011 01:57 AM
  5. voigts's Avatar
    Thank you. This is exactly what I was looking for. The 3500mah Ebay ones then should be the same size. Given the cost difference, I think I'm going to give them a try.
    I saw the pics, but I didn't know if there was a difference in the thickness of the i400 galaxy extended door (that comes with the 3500mah batteries) and the i510 Charge extended door.
    07-19-2011 08:42 AM
  6. dhp106's Avatar
    Post pics with your results too. I'd like to hear about that 3000 bat
    07-20-2011 02:20 AM
