- Forum
- More Android Goodness
- The Archives
- Android Central Archives
- Samsung
- Verizon Droid Charge
- Charge Accessories
androidified case review
- I acquired this Cruzerlite case a few days ago from amazon, and I couldn't be happier. I tried a couple more expensive cases, but they weren't nearly as nice. This one fits perfectly and adds very little bulk. All of the openings are in the right place, and the colors are appropriate for a professional environment. A very good value. This Cruzer Lite Androidified case is a great phone protection. Flexible, clean case thats very affordable and good quality! I would recommend them to anyone. Low profile case that does not make your phone feel bulky or add any more weight. Great case!! I have upload the videos I did for amazon. I only wish they made this style case for other phones. I have only found it for the droid charge.
Pros
Accesses to all the ports
Sturdy
Non-slip
Tight-fitting
Stylish Android Style
Price only 14.99 when I bought it{ I think its on sale for 12.99 now
Cons
Only made for the charge
Here are the video reviews I did for amazon06-16-2011 08:17 AMLike 0 - I need more reviews and bloggers. If you would like to review or blog about my case please post here thx.06-16-2011 12:56 PMLike 0
- I just purchased one from Amazon, I will try it out for $hits and Giggles. I think however it looks pretty much the same as the argyle patterned one I already have. I stopped using the Argyle case because the sharp edge of the screen side lip damaged the chrome finish on my old Charge, took the fake chrome right off. If this feels sharp or rough its not even going on the phone.06-23-2011 03:02 PMLike 0
- A couple times a week for cleaning or battery swapping. It took the chrome look paint off the front facing edge of the chrome band in the area between the power button and the upper right hand corner of the phone from scraping on it. That same edge can also lift up and damage screen protectors if they fit too tightly to that edge. "Tight fitting" isn't necessarily a good thing when it comes to some TPU cases.06-23-2011 05:00 PMLike 0
I've also done a lot of battery pulls and haven't had this happen to me yet. Although knowing this, I'll probably be more careful.06-24-2011 12:10 AMLike 0
- Forum
- The Archives
- Samsung
