1. AC Question's Avatar
    I got my s4 active in January of 2014 and have had no trouble with it until just recently. It will only charge if the cord is held in a certain spot, whether the phone is upside down or....hanging over a bottle of lotion. What do I do? Is it a charging port issue?
    04-23-2015 08:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It could be due to the charging port or the cable. Try a different cable--if the same problem occurs, then it's the port. You'd have to take the phone to a repair shop to fix it.
    04-24-2015 02:21 AM
  1. Battery Life on the OPO after Lollipop update?
    By worldspy99 in forum OnePlus One
    Last Post: 06-12-2015, 11:49 AM
  2. Replies: 2
    Last Post: 05-30-2015, 06:24 PM
  3. Battery Drain
    By joedevine1976 in forum Ask a Question
    Last Post: 04-24-2015, 02:32 AM
  4. Replies: 1
    Last Post: 04-23-2015, 08:28 PM
  5. Replies: 0
    Last Post: 04-23-2015, 06:53 PM
