1. AC Question's Avatar
    I charged my battery to 100% but after it goes to 40% it suddenly drops to a certain amount and it drains realy quick. It always happen to me
    05-20-2015 11:48 AM
  2. LeoRex's Avatar
    Two potential causes. 1) your battery calibration is messed up and your phone isn't displaying the percentage properly or 2) your battery is faulty.
    If you have root access, there are some battery calibration apps in the Play Store... they pretty much clear the internal mapping that the phone uses to determine what to report to you, the user.
    You say you switched the battery... maybe the new battery is defective.
  3. Klark Moses's Avatar
    Btw this is my thread and i will you show a photo of my battery report to make it more understandable.Why does my battery suddenly drop at 40?-screenshot_2015-05-21-00-42-35.png
    05-20-2015 12:00 PM
  4. VW Maverick's Avatar
    Welcome.
    What device do you have?
    Mav.
    05-20-2015 12:01 PM
  5. Klark Moses's Avatar
    Hey mav. Its a samsung s duos. I did not have a problem with my past battery but since i changed the battery, i have this problems since then
    05-20-2015 12:18 PM
  6. LeoRex's Avatar
    05-20-2015 01:27 PM
  7. Klark Moses's Avatar
    I dont think my battery is defective because i changed iy many time using warranty and i still got the same problem. Any app suggestion to download?
    05-20-2015 09:15 PM
  8. LeoRex's Avatar
    If you've swapped in different batteries and have run into the same issue.... that's not a good sign.... you phone's power subsystem might be screwed up and there really isn't an app that can fix that (phone would need to be serviced/replaces)
    I just read a bit from a Google engineer that those battery calibration apps are useless.
    05-21-2015 08:55 AM
  9. Klark Moses's Avatar
    I think my battery calibration is at fault here. My battery runs up to 10-13 hours just likr before. Bad thing i just dont really know when will my battery die. Thanks for the help
    05-22-2015 02:11 PM
  10. Aeon Angel's Avatar
    Yeah there all useless. Which is stupid since a lot of the get ratings of 4☆'s or higher. Lies... :-/
    06-26-2015 11:47 PM
  11. Aeon Angel's Avatar
    It'll do that then go back to draining. Mine has gone from 67% - 57% in 5 minutes!
    06-26-2015 11:49 PM
  1. Replies: 1
    Last Post: 08-04-2015, 05:23 AM
  2. Replies: 1
    Last Post: 06-22-2015, 02:57 AM
  3. Why does my Samsung Galaxy S6 have high battery use in standby?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-20-2015, 09:52 PM
  4. Should I change my Moto x 2014 for a HTC m8??
    By Agentemorgan in forum Ask a Question
    Last Post: 05-20-2015, 11:36 AM
  5. Why is my phone roaming when it shouldnt?
    Last Post: 05-20-2015, 11:24 AM
