1. AC Question's Avatar
    hi i am Ram, last one week i have faced this problem, mobile used 3 or 4 hrs, battery percentage not decreased, but suddenly display shows lesser then 10 percentange in my mobile. how to i solve this problem?
    02-29-2016 11:24 PM
  2. Denny P2's Avatar
    Have you flashed a custom boot.img or a custom ROM recently?
    03-01-2016 01:10 AM
  3. Laura Knotek's Avatar
    Welcome to AndroidCentral.
    What device do you have, and what version of Android is it running? Is your device rooted?
    03-01-2016 01:18 AM
  4. lncLESLIE's Avatar
    I have bought 3 phone chargers in the last 2 months? Why??
    02-06-2017 11:55 AM
  5. B. Diddy's Avatar
    We'd need more details than that. Which phone? What kind of problems are you seeing?
    02-06-2017 02:43 PM
  6. ankit3302's Avatar
    When any problem occurs in mobile phone, first step should be just simply switch off and on the device. Half of the issues get resolved doing this. If doesn't go for other options. In case of battery, sometimes this problem occurs when the battery becomes old. Sometimes, it may occur due to power tripping or other power related problems. Also sometimes when issues do not get resolved then we have to format the phone. Check all these things first then go to other options.
    06-01-2018 07:44 AM
  1. Replies: 11
    Last Post: 09-12-2016, 10:40 PM
  2. Fast Charging
    By tara_adele in forum Samsung Galaxy S6 edge+
    Last Post: 04-05-2016, 09:21 PM
  3. Anyone experiencing problems using Nova Launcher? [Note 5]
    By Issemann in forum Samsung Galaxy Note 5
    Last Post: 03-03-2016, 06:46 PM
  4. Have to pull the battery to get S4 to charge, how can I fix this?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-01-2016, 01:40 PM
  5. Why is my Note 5 No Longer Fast Charging?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 02-29-2016, 05:18 PM
