1. curney's Avatar
    Is there any reason to think that a 3rd party wireless charger will damage my phone from either heat or current? I can 3 for the same price as the OEM Samsung model.
    thanks!
    03-11-2016 09:24 AM
  2. nahoku's Avatar
    I don't use a wireless charger, but if I ever needed to replace my corded charger, I would only buy OEM. Why? Well, because the OEM made the charger for my device. I would hope they care that it works as designed... even though sometimes they suck just as bad. Still, I only buy OEM.
    Some people do have great success with 3rd party devices, and there are a ton of them available for sure. Getting 3 of them for the price of one OEM should throw up red flags though. I guess it did in your case and that's what prompted you to post here.
    03-11-2016 07:05 PM
  1. Replies: 0
    Last Post: 03-11-2016, 06:46 AM
  2. why my battery is draining fast
    By Raffaelo1 in forum Sony Xperia Z3
    Last Post: 03-11-2016, 01:28 AM
  3. Can an LG G2 AT&T use wireless charger?
    By AC Question in forum LG G2
    Last Post: 03-10-2016, 10:21 PM
  4. How fast does Huawei update?
    By Wybrem in forum General Help and How To
    Last Post: 03-10-2016, 09:12 PM
