1. TechNut79's Avatar
    I need a car charger and home (outlet) charger that can charge both a Note 4 and an LG G5. Can you recommend one for each? Thanks! I'm assuming one charger of each and a cable for each phone is what I need.
    11-11-2016 07:14 PM
  2. Ecm's Avatar
    If you're looking at a wall charger, these are my favorites. The QC 3.0 puts out the maximum your device can handle.
    Future-proofed with 2 @ QC 3.0 ports: PA-T16 Wall Charger
    Future-proofed with one QC 3.0 port plus 2 @ 2.4A. https://forums.androidcentral.com/e?...token=IrCnb_XX
    For the car, you can go future-proofed with this one: CC-T8 Dual Port Car Charger with Quick Charge 3.0
    For the most compact non-QC, this one is great. I have one, and the cover on the socket actually closes over it: CC-S1 Mini 24W Dual Port Car Charger
    All these are readily available via Amazon, etc.
    Laura Knotek and TechNut79 like this.
    11-11-2016 08:08 PM
  3. TechNut79's Avatar
    Thanks Ecm. I wanted to contact Benson Leung but didn't know how.
    11-12-2016 12:11 PM
  4. Ecm's Avatar
    No problems. Cheers!
    11-12-2016 12:27 PM
  5. TechNut79's Avatar
    Ok, one more question. How about the cables themselves? I'd like ones that won't break or stop working because of the bending at the ends. Preferably braided or kevlar? Thanks again.
    11-12-2016 01:35 PM
  6. Ecm's Avatar
    No doubt in my mind about those. Anker Powerline+. My wife and son were going through a lightning cable a month. I got them these, and they've been good for almost a year so far. We have the Powerline + in Lightning, micro USB and USB C. They're a few dollars more, but they last.
    TechNut79 likes this.
    11-12-2016 02:24 PM
  7. TechNut79's Avatar
    You've been awesome! Glad I came here to ask!
    Ecm likes this.
    11-12-2016 05:42 PM
  8. Ecm's Avatar
    You're entirely welcome.
    11-12-2016 08:23 PM
  9. TechNut79's Avatar
    The problem I'm finding after looking at these is that two of the chargers are not available and the anker powerline+ cables are not available in type c to usb 2.0. Unless I'm looking at it wrong.
    11-13-2016 06:40 PM
  10. Ecm's Avatar
    Here's the link for the USB C to USB 2.0. https://www.amazon.com/gp/aw/d/B01LN...cUvbUpU5562010
    11-14-2016 07:03 AM
  11. TechNut79's Avatar
    Ok, that's where I'm confused then. Both ends of the cord are the small type c plug. They won't fit those chargers. Do I need an adapter?
    11-14-2016 09:01 AM
  12. Ecm's Avatar
    11-14-2016 09:13 AM
  13. TechNut79's Avatar
    The 3.0 will work with those chargers? I'm so used to the 2.0.
    11-14-2016 09:19 AM
  14. Ecm's Avatar
    Yes, 3.0 is backwards compatible with 2.0 and 1.1.
    11-14-2016 09:31 AM
  15. Ecm's Avatar
    11-14-2016 09:31 AM
  16. TechNut79's Avatar
    And 3.0 is better with these cables, I'm guessing?
    11-14-2016 09:55 AM
  17. TechNut79's Avatar
    I wasn't trolling with that last part. I just don't know how 3.0 is better when it comes to charging. Data transfer I understand.
    11-15-2016 05:08 PM
  18. Ecm's Avatar
    Yes, 3.0 is approx 25% faster, IIRC.
    11-18-2016 07:08 AM
  1. Replies: 2
    Last Post: 11-14-2016, 09:31 AM
  2. Replies: 0
    Last Post: 11-11-2016, 07:14 PM
  3. Replies: 0
    Last Post: 11-11-2016, 06:29 PM
  4. Battery and over heating issue
    By susieee in forum Samsung Galaxy S7 edge
    Last Post: 11-11-2016, 06:00 PM
