1. Mooncatt's Avatar
    I have a photography project in mind that requires a battery pack to run some USB powered lights. I'm not very up to speed on which brands are respectable, but something like this is what I'm looking for.
    https://www.amazon.com/dp/B07BWBMZDL...cUvbUpU6430881
    Here's what I want:
    Dual type A outputs (quick charging not required)
    5,000-10,000 mAh capacity
    Battery gauge, preferably with a percentage readout instead of simple lights, bonus points if the gauge can also be turned off (I don't want the gauge to accidentally show up in the photos).
    Long and narrow (as opposed to being square or tube shaped), due to mounting on a pole or bar.
    Any other suggestions that would match those specs?
    12-27-2018 10:28 AM
  1. Another battery dilemma
    By Penthor in forum Samsung Galaxy S5 Active
    Last Post: 05-03-2019, 12:58 PM
  2. Will a 10W wireless charger damage the Note 9's battery? Belkin
    By felloffthetruck in forum Samsung Galaxy Note 9
    Last Post: 01-03-2019, 01:33 AM
  3. Will there or is there a Battery Case for the LG Q7 Plus?
    By Android Central Question in forum More LG Phones
    Last Post: 12-27-2018, 08:33 AM
  4. Battery Drains While Screen Is On? Please Help.
    By Dankees in forum Samsung Galaxy Note 8
    Last Post: 12-26-2018, 09:33 PM
