I just switched over to Cricket about a month ago. Everything was working fine, except yesterday my Nexus 5 started showing no Data.
The phone shows connected to cricket and I can send and receive calls. But there is just no data: No LTE , no HSPA. The funny thing is that it happened all of a sudden. The data was all fine until yesterday. Since then no luck with data, no matter what I do.
I've contacted cricket support 3 times and they've had me do the following:
Switch Wifi off
Delete APN and Re-enter the APN (did not work)
Reset APN to default (did not work)
Reboot the phone 10x and power off (did not work)
Take out the SIM 3x and power off ( did not work)
Airplane mode off/ON (did not work).
Basically they just told me that cannot do anything at this point.
Can someone please help. Is there any way to get data back on this phone?
The phone is a Nexus 5 unlocked from Google play store. It is running Android 5.1.1 LY48M build of lollipop. It is stock and rooted.
Thanks so much.
Switch Wifi off
Thanks so much.
