1. dbmorris99's Avatar
    ok so here is the story the droid 2 that i am trying to fix is the display on was rooted to enable wireless bluetooth tether. when my co-worker left the company he did a factory restore on the phone. now it has no display when it powers on but i can access the voice command and then the display works. anyone know the best way to fix this. and what is the best rooting program to do on the droid 2.
    09-10-2011 01:33 PM
  2. whiplash473's Avatar
    Maybe try another factory reset
    Sent from my DROID X2 using Tapatalk
    09-11-2011 10:30 AM
  3. dbmorris99's Avatar
    yeah i have tried the factory reset and does nothing
    09-11-2011 12:06 PM
  4. whiplash473's Avatar
    Go to VZW and see if they'll give you another one
    09-11-2011 04:08 PM
