1. Smitty_82's Avatar
    Team Get~R~Done has posted their D2G Rom-er Tool over on Droid Forums (link). This flashable zip replaces the D2G specific files over the incorrect D2 files on the ROM and is flashed AFTER the D2 ROM. Team Get~R~Done has tested this fix and works well with Liberty 1.5 or Fission 2.5.7. Known issues for other ROMs are listed in the post. D2G users looking to load custom ROMs should check this out prior to flashing any ROMs (unless the ROM is built specifically for the D2G.
    Karlito likes this.
    04-10-2011 09:01 PM
