Manofsteel927
Does the extended battery take a few charges to get optimal use? I have had it off charger for an hour and using web for 15 minutes and I am already down to 80%!!
I called Verizon customer service yesterday, and ordered an extended battery. They are in stock and on sale for $24.99. Get 'em while they're hot!
Anyone using the extended battery with the hd multimedia dock, or car dock?
What is an oem battery?
So has anyone found a store stocking these or are they having to order them?
Does it take anyone else a little over three hours to fully charge their extended battery (2760 mAh) bought from Verizon? I returned the extended battery and now trying another one, also what's the proper way of charging it? Just letting it get to about 5% and then fully recharging it? Lastly, is there any other apps besides Advanced Task Killer that you guys recommend to help get the most out of the battery? Thanks!
-PS they're still on sale as of 11/26 for $24.99 in store @ Verizon
I've had the extended battery since day one...I never let mine go below 15% before I recharge it. The standard dock charges mine the fastest; with the normal plug in an outlet a little longer...but never 3 hours. I would say I average 1-1/2 hours.
