Hello All,
When I'm driving I always have my phone docked and charging. I listen to pandora, navigate, etc. all at the same time. I'm not worried about the battery being drained as it is always plugged in. However, the temp gets up to 42+ degrees Celsius. Is there a max temp the battery should not go over, and is there a recommended temp as well? Like I said, I'm not worried about battery drain, but I am worried about frying my phone. Thanks for the help.
