All of a sudden sometime early yesterday morning my Bionic started running hot. The battery started draining like crazy. I have Watchdog installed and havent' received any alerts. When I look at my batter stats Android System seems to be running higher than normal at around 10%. I've restarted multiple times and even left my phone off for a while and turned it back on.
No other apps seem to be misbehaving according to Watchdog. My battery stats show a high percentage on the screen like normal, but Android system is now number 2 which I don't ever remember it being like that.
It's running so hot that my normal USB cable plugged into my computer and charging it doesn't charge it fast enough and the battery actually drains so I have to plug it into a wall to keep a charge.
I have no clue what to do besides a factory reset which I am not looking forward to. If I have to factory reset what's the best process of backing up everything and restoring.
