1. cfox10's Avatar
    I'm coming from the Fascinate where it was extremely easy to root and install new roms/kernels. I'm having a hard time trying to find out where to start with my new Charge. Any help would be appreciated, maybe a simple guide that goes over everything?
    Thanks!
    07-21-2011 08:35 PM
  2. vols fan's Avatar
    http://forums.androidcentral.com/dro...rsion-ee4.html
    Try this bossman. I did mine in less than 15 mins.
    07-21-2011 08:54 PM
  3. piizzadude's Avatar
    that is the one I started with the other day...good guide
    07-21-2011 09:43 PM
  4. cfox10's Avatar
    I just pm'ed you before I saw these replies.. Thanks for the link/guide.
    07-21-2011 11:19 PM
  5. cfox10's Avatar
    Dunno why I'm failing with this, but... I'm stuck in a boot loop at the samsung logo. I have CWM installed. Any ideas?
    07-22-2011 12:37 AM
  6. vols fan's Avatar
    You must hit reboot in CWM after installing the rooted kernal don't hit power off.
    07-22-2011 10:16 PM
