1. eumora's Avatar
    Please Help, I know nothing about rooting, I just purchased a phone off of ebay that was rooted, I don't have hardly any factory installed apps (i.e. navigation, backup assistant, or any of the described apps in the reviews) I am a rookie to these things.
    Please help. How can I unroot this phone?
    07-22-2011 05:05 PM
  2. vols fan's Avatar
    Read the how to return to stock sticky at the top of this forum.
    07-22-2011 11:14 PM
  3. eumora's Avatar
    where can I find that at? Im new to this.
    07-22-2011 11:57 PM
  4. vols fan's Avatar
    [ODIN] Stock Rooted ED1 (downgrade from ED2) [2011.05.18] - xda-developers
    Try this one to get the root off your phone. You will need to download Odin to your computer along with the other files listed in the post. This is a rooted version of ED1 but as soon as you boot it up after the flash just accept the OTA update of ED2 and EE4 and you will no longer have the root. Hope this helps.
    07-23-2011 12:05 AM
  5. eumora's Avatar
    do u know if there is an odin download for mac? because that one didnt work. Btw THANKS
    07-23-2011 12:14 AM
  6. vols fan's Avatar
    You have to use Heimdall on MAC. You should be able to google and find a download for it.
    07-23-2011 12:28 AM
  7. dulo's Avatar
    I am following the steps in the link you provided (Thank you), and am getting the an error in Odin. It says "MD5 hash value is invalid". Do you know how I can get around that?
    Thank you
    09-09-2011 01:18 PM
  8. piizzadude's Avatar
    redownload the file, if the hash check fails, it usually means it is corrupt.
    09-09-2011 06:07 PM
