1. ghostrider5666's Avatar
    I downloaded DC everything you need to root V2 and odined the file EE4stock_DXC.tar.md5 and it says passed on Odin but never works on the phone when it turn it on it goes to Samsung recovery. I have odined the file the same way as I did on my fascinate. What can I be doing wrong?
    08-14-2011 01:18 PM
  2. Landshark's Avatar
    Rooting is even easier now. Simply flash this file in ODIN, and you will have root and a custom voodoo kernel:
    http://dl.dropbox.com/u/14764513/Voo...ernel4.tar.md5
    Then you can also flash this CWM, which is the most current:
    0730_CWM_Recovery.tar.md5
    If you were planning on flashing a custom ROM, you can just do that without the above steps as all of the currently available custom ROMs for the Charge include root.
    ghostrider5666 likes this.
    08-14-2011 01:55 PM
  3. ghostrider5666's Avatar
    what custom voodoo kernel and would I have more chances of bricking the device with voodoo like on the fascinate?
    08-14-2011 02:00 PM
  4. Landshark's Avatar
    what custom voodoo kernel and would I have more chances of bricking the device with voodoo like on the fascinate.
    The file I linked contains the custom kernel. There's one basic, very important rule to remember: Don't flash a non-voodoo kernel over a voodoo kernel without disabling voodoo first. If you can remember that one rule, you will be fine.
    08-14-2011 02:06 PM
  5. ghostrider5666's Avatar
    I flashed it and got a phone, caution sign with exclamation mark and a pc?
    08-14-2011 02:15 PM
  6. Halo's Avatar
    You have yourself a soft brick (no worries, I've done it myself) Which ODIN file did you flash? I would suggest flashing it again.
    08-14-2011 02:28 PM
  7. ghostrider5666's Avatar
    08-14-2011 02:30 PM
  8. ghostrider5666's Avatar
    I have re-flashed it now a robot women says "convert data partition time is 10minutes" this is all new to me.
    08-14-2011 02:33 PM
  9. Landshark's Avatar
    I have re-flashed it now a robot women says "convert system is not available" this is all new to me.
    Unlike the Fascinate, with the Charge make sure you leave the battery in when flashing through ODIN. Disregard, it is working now if you heard the female robot say "convert data partition, time estimated 10 minutes" You will be good to go.
    08-14-2011 02:36 PM
  10. ghostrider5666's Avatar
    Ok good to know.
    08-14-2011 02:37 PM
  11. ghostrider5666's Avatar
    Whats with the women's voice and I'm stuck on the Samsung screen? "convert data partition time is 10minutes"
    08-14-2011 02:38 PM
  12. Halo's Avatar
    Don't panic. Voodoo is converting the Samsung .rfs system files into ext4 files. It can take anywhere from 5-15mins. After it's done, your phone will reboot and you'll be good to go.
    08-14-2011 02:39 PM
  13. ghostrider5666's Avatar
    Sweet thanks for the help.
    08-14-2011 02:40 PM
  14. Halo's Avatar
    I've always taken the battery out of my phone while using ODIN. Never had any problems. From what I read on the forums, it seems to be hit or miss. Some have to leave it in, others have to take it out.
    08-14-2011 02:43 PM
  15. ghostrider5666's Avatar
    What voodoo kernel is that and how is battery life?
    08-14-2011 02:56 PM
  16. Halo's Avatar
    I'm assuming you're talking about the one listed in my signature? It's basically a beta kernel at the moment. So far, battery life is pretty good. I can usually go 10-12 hours with (what I would consider heavy use) before I have to put it back on a charger. I'm perfectly happy with that considering the fact that I'm also overclocked.
    08-14-2011 03:02 PM
  17. ghostrider5666's Avatar
    No the one in the link landshark provided. Also how do you boot into CWM on the charge?
    08-14-2011 03:04 PM
  18. Landshark's Avatar
    It's the voodoo kernel from jt1134. Probably the first voodoo kernel the Charge had. There are others you can try, but it's nice this one gives you root, voodoo kernel, and cwm all in one package.
    08-14-2011 03:07 PM
  19. ghostrider5666's Avatar
    How do you boot into CWM recovery? Every time I try its just stays at the Samsung screen.
    08-14-2011 03:16 PM
  20. Landshark's Avatar
    Hold volume up, power, and home buttons down until you see the samsung logo flash on the screen for the second time. As soon as you see the samsung logo appear for the second time, let go of all three buttons.
    08-14-2011 04:04 PM
  21. ghostrider5666's Avatar
    I have done it like 10 times but CWM never comes up it would hang at the samsung screen then boot. Also my phone comes up as a CD Drive now.
    08-14-2011 07:41 PM
