1. TGreg104's Avatar
    Okay so i came from gummy 1.9 to 2 and it does work great and its fast but i get multiplw restarts a day.. like ten. And now i keep getting andriod.market stopped working and also process android.media. and on top of it my phone was emitting a sound that was like when you dial a wrong number. Help
    09-08-2011 02:46 PM
  2. Halo's Avatar
    I would wipe data/cache, do a factory restore with CWM and reflash 2.0.
    09-08-2011 02:53 PM
  3. TGreg104's Avatar
    I did that already twice and it does work for like three daya and its uust back to the same. I may flash back to ed whatever and ota to ee4 and re root idk
    09-08-2011 03:02 PM
  4. piizzadude's Avatar
    really what is sounds like to me is that your phone mya not like to be either overclocked or undervolted. I get the same issue when I undervolt at all.
    I would download voltage control and get rid of the OC's in the Kernel and make sure the UV's are normal. see how that goes....
    09-08-2011 04:44 PM
