1. TGreg104's Avatar
    My computer wont recognize my phone. I have the samsung drivers installed and I installed the sd card fix .zip through cwm. It was working earlier today and after work it wasnt. Tried reinstalling the samsung drivers and the sd card fix twice and restarted both my comp and phone. no go. Any ideas?
    09-17-2011 03:05 AM
  2. piizzadude's Avatar
    Are you using a laptop? If so, use one one of the ports on the back. I would also say try a different port.
    09-17-2011 11:55 AM
  3. TGreg104's Avatar
    Okay thanks ill try that and let you know. Its the same port i use to odin though so idk.
    09-17-2011 12:20 PM
  4. TGreg104's Avatar
    Still not working :/ I tried all the ports.
    09-17-2011 12:41 PM
  5. TGreg104's Avatar
    I got my sdcard menu to come up for a second and I tried to copy a file to it and its write protected. Idk if that helps
    09-17-2011 01:12 PM
  6. TGreg104's Avatar
    When I plug my phone in I get this:
    SAMSUNG Android USB Composite Device Ready to use
    SAMSUNG Android USB Modem #2 Ready to use
    SAMSUNG Android USB Diagnostic Serial Failed
    Port (WMC) (COM7)
    Port (DM) (COM)
    09-17-2011 02:19 PM
  7. Midnight_Ninja's Avatar
    I would try the write protection fix:
    http://forums.androidcentral.com/dro...oot-users.html
    Also, on your phone, try going to the menu and put 'ask' on the usb connection settings. For some reason that helped when I couldnt mount my sd card.
    And as another fix, uninstall and reinstall the drivers
    09-17-2011 02:43 PM
  8. piizzadude's Avatar
    Go with what ninja said, that should do the trick, at least for the SD card issue.
    09-17-2011 03:15 PM
  9. TGreg104's Avatar
    Thanks guys. How am I suppose to get that sd card fix on my sd card if my comp wont recognize it?
    09-17-2011 03:35 PM
  10. TGreg104's Avatar
    Nvm I already have that sd card fix on my sd card and installed it like five times :/ I hope I can resolve this without having to factory reset etc.
    09-17-2011 03:44 PM
  11. piizzadude's Avatar
    To answer the first question in case it comes up for someone else, take it out of the phone and use a card reader to put the file on
    next up try this, pull the battery plug it into the USB and try to get to download mode. See if odin recognizes it
    09-17-2011 04:35 PM
  12. Landshark's Avatar
    First, just to cover every possibility, make sure usb debugging is enabled under menu=>settings=>applications=>development. If so, connect phone to your computer with usb debugging enabled then restart your phone. See if that helps, it almost always worked on the Fascinate.
    09-17-2011 09:03 PM
  13. vi3tboiii54's Avatar
    okay guys im having a similar problem too, ODIN isnt recognizing my device even though its in download mode. I installed/reinstalled all the drivers and still nothing *sigh*
    09-17-2011 11:24 PM
  14. Landshark's Avatar
    Which version of ODIN are you using and is the battery in the phone?
    09-17-2011 11:42 PM
  15. vi3tboiii54's Avatar
    yep tried putting the battery in and using both 1.82 and 1.3 no luck
    09-18-2011 08:21 PM
  16. Landshark's Avatar
    see if you have any luck with ODIN v 1.85:
    http://forum.xda-developers.com/atta...3&d=1304094576
    09-18-2011 08:36 PM
  17. vi3tboiii54's Avatar
    no luck either i think i soft bricked it
    09-19-2011 02:53 AM
  18. Landshark's Avatar
    Just want to eliminate one more thing, did you get the drivers directly from the Samsung web site or did you download them from a thread? I always use only the drivers directly from the Samsung web site and have never had a problem. Also after you download the drivers make sure you connect the phone to your computer and complete the driver installation with the phone on before trying to connect in download mode. I always make sure I can connect to my pc and access my sd card before going into download mode and use ODIN.
    09-19-2011 01:39 PM
  19. TGreg104's Avatar
    Im wondering if its something wrong with gc2.0gb or maybe just the file i downloaded. I flashed back to ed1 and ota to ee4 and my usb worked again. then i went back to gc2.0gb and it worked for 30 mins and now it doesnt read again. oh well.
    09-19-2011 06:30 PM
