1. xnadira's Avatar
    I rooted my Charge as soon as I got it about a month ago and everything was fine until yesterday I couldn't get my PC to acknowledge my phone's SD card. I backed everything up and reinstalled gummy charge from zip along with the SD card fix I then did the update to 2.1 after. I'm now stuck on the Android system recovery screen <3e> It says Samsung Recovery Utils for BML. I wiped it and tried to flash back to stock & CWM but I'm getting the same screen. I can only go from here or back to download mode. It says under my options:
    -- bootmode=7 from cmdline...
    -- Movi_check Start...!!!
    checksum confirmation need_checksum[0]
    Not need checksum confirmation
    -- Movi_check already executed!!...
    -- movi_checking done!...
    # MANUAL MODE #
    Please if anyone knows how to help, I'd appreciate it!
    11-23-2011 12:11 PM
  2. Charge5150's Avatar
    have you tried to flash with odin?? got get the stock debloated 2.3.6 with new radios and and flash Via odin. What CMW where you using when doing update from zip?
    11-23-2011 12:43 PM
  3. xnadira's Avatar
    Hmm. I was going back to froyo, and I had been using the file listed as 0817 charge recovery
    11-23-2011 02:24 PM
  4. Charge5150's Avatar
    go to rootzwiki "imnuts" posted a howto to get back to EE4 for the OTA that is about to be pushed
    11-23-2011 02:31 PM
