1. kraisydave's Avatar
    First, thanks to Android Central and all the people here as you have helped me a lot. I am not a dev, but wanted to give back so I made these videos in hopes to help out.
    One is on rooting without deleting you data while keeping the current updates from Verizon. The other is common problems people run into while rooting. If you check out my youtube channel there are more vids on backup and running ROMs under Android Tips. If you have a vid suggestion let me know and I will make it. Thanks....
    Updated Rooting Method
Common Rooting Problems
    01-21-2012 10:48 PM
  2. izzyd's Avatar
    Couple of questions, I have a DC and I had gummycharge 2.0 before then I updated to 2.1 but I kept getting random reboots, so after searching on the forums I found that it was because of CWM I had the old version (cwm 4.0) so I rooted back to stock and started over but when I downloaded the new CWM 5.0 I was able to root the phone but now when I go back into recovery its not going into CWM.... So my question is should I still use CWM 4.0 or look for a newer version? Also when I do root to gummycharge 2.0 then to 2.1 I have the stock radio is it necessary to flash to get the EP1 radio or is the EP4 radio ok? Thanks for your time.
    02-22-2012 04:04 PM
Tags for this Thread
