1. lateralus124's Avatar
    So I was using Titanium Backup pro with my rooted droid charge (stock rom) and I hit the widget button Freeze all processes or something like that, thinking it would just freeze the programs I had selected to freeze. It froze my phone, so I took the battery out and now I'm stuck in a boot loop. It will get to the graphic of the word Droid exploding and keep looping back to that. What can I do to fix this?
    03-20-2012 09:44 PM
  2. Cyber Warrior's Avatar
    Did you by any chance make a nandroid backup of the stock ROM?
    03-20-2012 10:54 PM
  3. Bearii's Avatar
    I've got a similar problem. It's a rooted, s-off HTC Wildfire S on vmobile. I used titanium backup pro and was fiddling with the settings and decided to undo the davlik rom links I had set up. When it rebooted the device now keeps rebooting, won't go past the vmobile start up splash.
    I do not have a nandroid backup. : ( Any chance I can fix this?
    03-21-2012 10:45 AM
  4. Cyber Warrior's Avatar
    Yea.. that will happen.. you never want to mess with system files when using Titanium. Just use it to backup your Play Store (Market) apps and data and that's it. If you're going to freeze something... make sure you know what it does first.
    You're going to have to put the stock image/rom back onto the phone.
    http://forums.androidcentral.com/dro...esort-fix.html
    03-21-2012 11:42 AM
  5. Bearii's Avatar
    Thanks CW! Do you know if I'll be able to use my Titanium backup to restore my phone once I can get it back on again?
    03-21-2012 07:48 PM
  6. Cyber Warrior's Avatar
    Yes you can.. just don't restore any system apps/settings... only Play Store apps.
    03-21-2012 08:24 PM
  7. cecep indrawan's Avatar
    can help me, i have sony xperia p lt22i , boot loop after using titanium backup pro, i selected freze all and after do thar, my phone restart, and stuck
    11-18-2014 12:57 AM
