Registered here specifically to say "THANK YOU"!!!
The hard work y'all do is simply amazing! Brings me back to my "Blue Box" days....
I'm having the same problem as others regarding the Calendar app...it's something I do use, and I'd like to be able to have that one back.
I've done the /system/app thing, and rebooted several times, also done a factory wipe and reinstalled my google acct, and still no calendar.
I'll try a direct install - any other help would be greatly appreciated!
Thanks again!
anyone on that has the vvm or calendar problem?
If you have any experience with sdk you can try the following
1) open CMD
2) switch directories to your adb (mine is c:\android\platform-tools)
3) type this one at a time:
adb remount
adb push c:\CalenderProvider.apk /system/app/CalenderProvider.apk (the c:\ part is where the apk is located)
On a different note, the gmail apk is missing from the rom. No biggie. I just had to dl it from the market.
what am i chopped liver?i have an updated version but i need one brave tester
If u want to wait about 1.5 hrs, i can do it when i get to work
I want to get to bed soon , as is im only going to sleep 3 hours, i was working on this all night
Can you explain exactly how you got the calendar working?
I can't get it working for the life of me.
Thanks!
Put up a screen shot so I can see what DroidXcon has done with the notification pulldown and I will swap it out when I get the framework-res.apk from DroidXcon to work on a mod for him (I'm running a Samsung Epic 4g so I can't flash it..)u forgottttttt to make the notification bar transparent
but i already told you that
Ahh the life of a inspiring ROM dev... Good stuff isn't it? DroidXcon, I've spent so many hours starring at my screen trying to figure out things while playing dev its not even funny... I know where your coming from...I want to get to bed soon , as is im only going to sleep 3 hours, i was working on this all night
Thanks and how can I donate to your starbucks fund. Not only did u hook us up. But you made it simple stupid for the fake arsse geeks like myself. Will give it a try over the long weekend.
If you need any more testers PM me and i will try it...Work is slow today so I gots time to play
I updated the OP , vvm and calendar are working.. and try out the usb mounting feature, im prod of that lol
