evowannabe
Full battery pop up option works as advertised. No more bright screens in the middle of the night, thanks
To disable the lock screen (and power down pop up), go back into the Dialer and use the code *#7594#, select Shutdown and press the Home button. This, I have confirmed, does work on the Charge.
The theming looks great, but are the borders of the boxes supposed to be red and blue?
Question: How do I switch back to either the glass or puzzle unlock screens?
I understand this works for a no lock screen but I don't want to disable the pop up power down/ restart. Is there a way to do just the lock screen?
how do you access recovery mode?
what are you trying to do from recovery mode?
recovery can be reached by holding Volume up+home button+power , samsung will flash twice then let go and you will enter recovery
E: Missing bitmap icon_clockwork
(Code -1)
i was just wondering for future reference.
thanks!!
oh, and one more thing:
on the initial startup recovery, i got an error message:
Code:E: Missing bitmap icon_clockwork (Code -1)
Is this something I need to worry about?
Thanks again!
Does the voodoo kernal support Voodoo sound yet?
Go to Dialer and enter *#83786633, then press the home key
Go back into the Dialer, clear those numbers, then *#22745927
Now a screen will appear asking for the SPC Code, enter 000000
Press the Hiddenmenu Enable radio button, then press home button
There is also the option to disable the full battery pop up, but I'm not sure if it actually works or not (I'll be able to find out later tonight). *#3844228#. It allows you to disable it, but the option never actually worked on my Fascinate, so I don't know if it will work on the Charge.
