anyone having battery issues with altered beast
I know I have read a couple people having a battery drain with altered beast and would like to ask a couple questions
what version are you on?
did you do a factory reset after loading the rom?
did it just install over your current rom?
I installed AB over my rooted rom and was not getting great battery life for what I was doing. So I did a factory reset from cwm and reloaded everything exactly how it was before I restored and it seemed to cure what ever my problem was.
When I first installed AB it did not wipe my phone, everything was there like before the rom was on it, ringtones, settings everything. I would wantch my phone drop 3% sometimes just checking an email, even with the screen off not using the phone it would chew through 5% an hour.
Now after restoring my phone last night it has been almost 9 hours since I took it off the charger and I have only used 8%
I was also getting a low quadrant score, 1101 before and 1500+ after the restore
if you are having battery issues you might want to try restoring the phone
