Maybe I missed it, but does anyone know what happens if you install EE4(OTA) on top of AB v4?
It's early and I haven't had my coffee yet....
I am still waiting for EE4 OTA, but as a cautionary rule you should never accept any OTA updates if you are not running a stock ROM.
EE4 update installed via CWM will update everything but if you downgrade you at least don't lose the radio update which is the key part, everything else will be baked into the ROM.
BTW I am attaching imnuts latest build of CWM Recovery that can be found at the other place, but here are his notes as well.
[RECOVERY][6-11-11]Clockwork Mod Recovery
So I spent the weekend working on some things, and one of them was trying to get CWM fixed up. I believe that I have all of the problems fixed, but I can only do so much testing on my own. The button mappings work, and I have been using this and similar versions (bugfixes and such added since then) for about a week now. I completely removed backup/restore as my attempt to get it to work properly didn't work, so I'm guessing something else is wrong with it than what I initially found and reported to Koush. I will try to keep this updated as updates come out for CWM as well. Flash with Odin/Heimdall
Button Mapping
Vol Up/Down - Navigate through the menus
Power - Select Item
Menu/Home/Back/Search - Go Back to the previous menu
Known Issues
Backup/Restore is still broken. DO NOT BACKUP OR RESTORE WITH CWM! CONSIDER THIS YOUR WARNING - Should no longer be an option you can see.
Failed to mount /sdcard error(s) - Perform the following commands with ADB:
Code:
adb shell
umount /sdcard
rm -f /sdcard
mkdir /sdcard
exit
Type each line in and press enter. Do not skip a line, or you may loose data It seems to have worked for anyone that tested and had this issue.
Download:
New_CWM_Recovery.tar.md5
