1. Beezzy's Avatar
    Is there any way to possible use onebpf the soft keys as a physical camera button? I just thought that would be a cool thing to do to make up for the lack of one. I hope a dev can see this and maybe come up with something. Also fix the auto rotate while your at it
    Thanks in advance if anyone can pull it off!
    Sent from my SCH-I510 using Tapatalk
    05-25-2011 11:23 AM
  2. xaerospace's Avatar
    I would love to have this feature. I am not a fan of clicking the screen. There is an app called Littlephoto that allows you to use the volume key to take a pic. Of course, this isn't the right solution cause that is the zoom key. It would be awesome if it was the search button.
    We can hope.
    08-01-2011 11:11 PM
  3. piizzadude's Avatar
    08-01-2011 11:17 PM
